Latest update on PCM
Tagower
ohio
Finally recieved my PCM from Wranglerfix. I was tracking it and it got stuck at UPS Miami hub for 42 plus hours. So much for 2 day shipping. Installed it and the jeep fired right up. Took it out for a test drive and all is good. Thanks again to Chris @Chris and AndyG @AndyG. For the replies and convincing me I really needed to call Mark @Wranglerfix. And a special Thank You for Mark @Wranglerfix for our conversation and your help getting the TJ back on the road quickly. Mark is truly one of a kind.
Thanks for the update!
Mark is the best. He's fairly priced, easy to work with, ships super fast, and is an all around great and friendly guy.
If only more people knew how to run a business like Mark does.
Thanks again! I do have a question though. When I first started it and test drove it, it seemed like at the first stop sign it wanted to almost stall but didn't. Next stop sign same just not as bad, next stop even better. Now it seems fine. My question. Does the new PCM have a learning Curve? Maybe just a fluke from setting.
Reactions: Wranglerfix
The ecm has to go through a drive cycle. The fuel monitor and evap system also have to be set.
Has the Jeep been setting for awhile?
I would run a tank of 93 octane and a can of fuel additive if it has been setting.
Sitting for about 3 or 4 weeks while trying to get the problem diagnosed and fixed.
