Hey guys, new member here. I have used this forum quite a bit but haven't posted here.
Yesterday I was changing the O2 sensors and ran into a couple issues.
I have a 2005 SE 4.0L with a 42RLE.
So I changed the O2 sensors and didn't realize that I had accidentally knocked off the vacuum hose for the brake booster. So it idled higher than normal and the brake pedal got really firm. I figured the high idle was an issue with the new O2 sensors but couldn't figure out the brake issue. I tested out the brakes several times and had to press really hard to get the jeep to stop especially when it was idling high. I ended up seeing the vacuum hose off and fixed it which fixed the high Idle and the brake issues.
Now the transmission won't shift out of park when I start the Jeep. If I turn the ignition to accessory I can shift the jeep into neutral and start the jeep then put it in gear. The only thing I can think of is when I had to press the brake pedal super hard something might have happen and now a brake sensor isn't working which is keeping the shifter in park when running.
I saw the chopstick fix but if the shifter work fine when the key in in ACC, it just doesn't work properly when the engine is running. Thats what makes me think it may be something else.
Thanks guys, any help is appreciated.
Jay
Jay
