I know I can't be the only one that's done this. What should I do with this bent lower control arm mount on the axle housing? Replace it with something stronger?Bend it back? Bend it back and add mini skids?
Looking down the length of the arm, it looks straight, it's just the flanges that are folded a bit. The bracket is bent though.Is the bracket bent or the arm that's bent?
I think @mrblaine had found some. You can search through his post history.On second thought, does anyone make stronger replacement brackets that don't compromise on clearance? Wanna consider all my options here.
Big crescent wrench, prybar, big hammer. Wrestle it back into shape. Might have to pull out the arm to get at it. I have bent mine a couple times. Need to upgrade since I keep smashing them. That or get bigger tires so they stop dragging on the rocks. Maybe both?
When I get bigger tires I'm sure I'll find the corresponding bigger rocks to drag them on.That or get bigger tires so they stop dragging on the rocks.
I have thicker mounts welded on the front axle. Need to do something for the rears sooner or later. Now that I am towing, I tend to worry less about it. That is until it ruins my day on the trail. Add it to the list.Have you put a skid on them yet? Even on 37s mine find rocks.
Where from? Or custom?I have thicker mounts welded on the front axle.
Iron Rock Offroad makes the best fitting ones I've found so far. I don't like that they are 1/4" but they work very well.On second thought, does anyone make stronger replacement brackets that don't compromise on clearance? Wanna consider all my options here.
Do the mini skids fit those well?Iron Rock Offroad makes the best fitting ones I've found so far. I don't like that they are 1/4" but they work very well.
I would have bet you a paycheck I saw a logo. Took some pics and no logo to be found. Don’t know what I thought I saw. Guess I “assumed” these were added on due to the shitty welds.Where from? Or custom?
Yeah, looks thicker than stock, maybe 1/4". I think I'm gonna go with the iron rock offroad with the rockjock skids.I would have bet you a paycheck I saw a logo. Took some pics and no logo to be found. Don’t know what I thought I saw. Guess I “assumed” these were added on due to the shitty welds.
You tell me, they look thicker than stock to me. View attachment 221585View attachment 221586View attachment 221587
