What to do with a bent or folded lower control arm bracket?
Tob
Weimar problems require Weimar solutions
Lake Charles, Louisiana
I know I can't be the only one that's done this. What should I do with this bent lower control arm mount on the axle housing? Replace it with something stronger?Bend it back? Bend it back and add mini skids?
Dont go with Artec--it will place your arm in a lower position (read: less ground clearance), and change the vertical separation of your front control arms. Go with the weld on plates from rock jock.
Reactions: Tob
Thanks for the input. I certainly don't want add any low hanging rock magnets. I'll be putting in Savvy arms soon, so I guess I will bend the brackets back straight as I can and add the mini skids then.
On second thought, does anyone make stronger replacement brackets that don't compromise on clearance? Wanna consider all my options here.
It looks like you might be able to put a wrench on those and straighten them out.
I think @mrblaine had found some. You can search through his post history.
Reactions: Tob
Big crescent wrench, prybar, big hammer. Wrestle it back into shape. Might have to pull out the arm to get at it. I have bent mine a couple times. Need to upgrade since I keep smashing them. That or get bigger tires so they stop dragging on the rocks. Maybe both?
Reactions: Tob
Have you put a skid on them yet? Even on 37s mine find rocks.
I have thicker mounts welded on the front axle. Need to do something for the rears sooner or later. Now that I am towing, I tend to worry less about it. That is until it ruins my day on the trail. Add it to the list.
Installed by the PO. They have a logo cut into them, will try to get a picture. Just noticed they are thicker material when installing my new arms.
Reactions: Tob
Iron Rock Offroad makes the best fitting ones I've found so far. I don't like that they are 1/4" but they work very well.
Reactions: Tob
Where from? Or custom?
I would have bet you a paycheck I saw a logo. Took some pics and no logo to be found. Don’t know what I thought I saw. Guess I “assumed” these were added on due to the shitty welds.
You tell me, they look thicker than stock to me.
Reactions: Tob
