Typical 3/8" synthetic winch line has a breaking strength of over 15,000 lbs depending on the manufacturer. (Quadratec's in house rope is 18,000 lbs for example.) Once you go to a snatch block and back to your vehicle that's able to be putting over 30,000 lbs on the tree saver, snatch block, shackles, etc before the winch line breaks. (A 10,000 lb winch will only put 20,000 lbs onto those items in that scenario.) Plus, people use shackles to connect dynamic recovery ropes and metal shackles aren't designed for dynamic loads. Does the 7 ton shackle make a huge difference over a 4 3/4 ton shackle? No. But the cost difference between the two Crosby shackles is insignificant. You only need 3 or 4 of them in your recovery gear, spend the money so you don't wind up with 2 lbs of steel launched at your head at hundreds of miles per hour.
You'r recovery gear should be capable of handling at least 3 times your rigs trail weight but the absolute LAST thing I want to fail is the steel shackle or anything further from the jeep than it (like the tree saver or snatch block). Buy quality USA made products of proper strength rating and mitigate the hazards.
