Garmin 5" or Garmin 6"?
Fishtaco
TJ Expert
Perth AU
About to buy a new GPS and ditch the street directory book, looking at the Garmin drive but the 6 inch may be a bit too big on the TJ, Would the 5 inch be better for the small windshield? Bigger isnt always best sort of thang? my jeep trail Guide is just way too small to read in the centre and I want a sat nav on the drivers side.
Cheers
I’d go 5” but have you considered upgrading the stereo to include nav?
https://www.amazon.com/dp/B083YTCZXT/?tag=wranglerorg-20
Actually I am pretty impressed with the factory stereo in my 06 and am happy to keep it old school, once you start with a gps stereo then you want a reversing cam then park assist then lane departure warning then auto pedestrian/crash brake assist! so at this stage I just want a good sat nav. I dont want to buy a 6" if its going to block too much intersection/roundabout vision. so you think the 5 inch would suit the TJ better.
Cheers
Reactions: Zorba
Have you tried using the Gaia app? Get any tablet or phone and it is (supposedly) one of, if not the best mapping systems out there.
This. I have a Garmin inReach and use Gaia and the Garmin app on my phone. A lot of the overland guys use a tablet.
Reactions: Rick Flair
I don't like blocking windshield either. Here is a pic of my 5 inch Garmin. I just upgraded from a 4.3 so it seems big to me but doesn't block anything. My phone holder is next to it.
Mine's a 4.something:
And is just fine. It gripes me to no end that I feel compelled to put a screen of ANY type in my car, I sure as Hell don't want it in the middle of the dash - or some gargantuan tablet! This ain't a Tesla.
But check out that handsome dude in the mirror!
Reactions: Vasq and Fishtaco
I have the 6" mounted to the windshield over the dash tray, it does block a bit of the view but I haven't had a problem with it yet
I was going to mount it up on the top windshield header but I hang my sunglasses on the footman loop up there
How did you route your wires.
I use a Drive 65. Definitely not too big but the smaller one work just fine. One reason I like the larger screen is that as you approach highway exits the screen splits with a list of services. A few other notices chime in occasionally. The larger screen is easier to see at a quick glance. I do much prefer the glass touch screen over my older pressure sensitive Nuvi.
I bought the unfortunately expensive Garmin hard wire harness from Amazon. I tapped into one of the 12v outlet wires behind the switch panel. One is always on, the other is on with ignition. I chose to use on with ignition so I never have to power up or down the Garmin. The wires run behind the dash to the A pillar trim then over to the center of the windshield. If your TJ is an older version (02 or older) I dont believe the trim is there and making a clean looking install will be more difficult.
