Hey folks, Spent my day replacing heater hoses, upper/lower radiator hoses and thermostat. Went to add coolant (with jeep off) and its leaking at the bottom of the thermostat housing. Ggrrrrr! I replaced thermostat gasket and tightened to 15lbs. What do you all think it is? Bad. gasket/housing? I was sure to clean off surface and razor blade all the previous gasket residue. I even put a small coat of RTV on the gasket. Maybe that is where I messed up. Please advise.
THanks, Matt
THanks, Matt
