My drivers fender is kind of busy. Compressor, windshield reservoir, cruise control servo, and Evap canister purge valve.. At least my 05 doesn't have the charcoal canister on the fender like the 97-02. I knew it was going to be a challenge with locating it but wanted to wait until it arrived before making a decision. The easy way would be to mount the PSC reservoir beside the master cylinder using the provided bracket but I've seen pictures and have read forum pages that it should be mounted as close to the pump and if possible, on the fender.
I don't want to lose windshield fluid and cruise control is often used. Initial thought was to relocate the cruise control servo to beside the master cylinder and put the PSC reservoir in it's place. However, this may only gain a 6" shorter feed line than if using the PSC master cylinder mount. Is it worth the effort? The other though was a smaller windshield fluid bottle but can anyone suggest a replacement?
