Looks like I have the tall resi. Do you happen to have the part number for the one you have?
SR-145Looks like I have the tall resi. Do you happen to have the part number for the one you have?
Not seeing that available. Is it a call PSC thing or do you happen to know where I could order one?SR-145
I have placed at least a 100 orders with them. I have called them in so I don't really know. I have never ordered a single thing from the website. In fact, the only thing I have ever used the website for is to get the phone number so I can call in my order.Not seeing that available. Is it a call PSC thing or do you happen to know where I could order one?
Toximus’s thread came up and said they no longer make them. Hopefully that’s not the case.I have placed at least a 100 orders with them. I have called them in so I don't really know. I have never ordered a single thing from the website. In fact, the only thing I have ever used the website for is to get the phone number so I can call in my order.
I got one not that long ago. Actually several in the last few months.Toximus’s thread came up and said they no longer make them. Hopefully that’s not the case.
Great, I’ll call MondayI got one not that long ago. Actually several in the last few months.
Can you say more about when it will not work? The conditions, why it doesn't work, etc. That would be helpful.The problem with doing it that way is it works most of the time. Closer works all of the time.
I've been building and installing HP steering since 2000 when I got the first upgraded steering gear and pump from Tommy Lee. I've been through Lee's offerings, then Howe, and now PSC. Over the years as we ran into an issue and solved it, we brought that solution forward and it became part of every new install.Can you say more about when it will not work? The conditions, why it doesn't work, etc. That would be helpful.
Where on the inner fender are you trying to install it?So, here goes... I'm not entirely certain the Reservoir I received is the "short version". At 7-3/8" tall, can anyone measure theirs to see if mine is bigger or smaller?I had intentions of mounting on the fender but at that location, I will not be able to close the hood. Obviously depicted with my avatar, I have Metalcoak fenders so they could have a higher inner fender than most... However, I thought I read somehwere that PSC reservoirs can be mounted on highline fenders.
Same location as washer bottle.Where on the inner fender are you trying to install it?
x2.It will fit where your cruise control/washer reservoir is. Your inner fenders are not higher than the hood line.
That is my next approach. I pulled the cruise and evap purge out of the way and for the hell of it, I mounted the reservoir using PSC's master cylinder bracket. With the 90 deg anti splash fitting, I got the reservoir to a comfortable elevation. The bottom of the reservoir is lower than the height of the inner fender... Not by much. When I raised the reservoir in the bracket to match the fender height, the anti splash fitting just touches the hood.x2.
You'll likely not be able to run the feed line if you place it where the washer fluid is now anyways since it would be too short. Try and get it as far back on the flat surface of the fender as possible for clearance and ease of running the lines. The Cruise can easily be relocated.
Mine’s the taller over 8” version. No way to set it on my metalcloaks.So, here goes... I'm not entirely certain the Reservoir I received is the "short version". At 7-3/8" tall, can anyone measure theirs to see if mine is bigger or smaller?I had intentions of mounting on the fender but at that location, I will not be able to close the hood. Obviously depicted with my avatar, I have Metalcoak fenders so they could have a higher inner fender than most... However, I thought I read somehwere that PSC reservoirs can be mounted on highline fenders.
I like the approach but will the height of the reservoir at that location place the fill line opening lower than the pump?Mine’s the taller over 8” version. No way to set it on my metalcloaks.
I ordered a small aluminum angle that I will bolt to the fender between the radiator overflow and the fender. Then I’ll bolt the reservoir on top. Also ordered a strip of steel that I can bend and utilize the bolt holes on the rear.
The ports on the reservoir will face the driver.
At least that’s my plan for now. I can test fit once everything shows.
