i need a punch list. or a punch me list i did this to myself.
i'm gettin overwhelmed and i'm beginning to loose focus bouncing from task to task like a lunatic.
and i'm sure this is not gonna be a complete 1st draft.
front end needs the frame TB bracket reworked, or beefed up............................. i have anything i need to fab this.
the ARB compressor needs wired at the switch..........DONE
the harness for the rear locker needs pushed in and tied at the switch. the wire from the diff is in the cab........DONE
the rear brakes need piped.....i ordered the flex line, adapter fitting and T today,.........all piped and secured to the axle, just need bled.
the fuel line is run, needs tied in at the rail and the cell...........tied in at the rail
finish the fuel cell tie downs. ...........gonna work on this tonight..............................DONE
the rockers need finished......a little weld, a trim and some paint.
rear corner armor needs couple more holes drilled, the bottom corners at the gate run into my torque box ends plates.........DONE
the bumper needs installed.......weld brackets on the frame and drill it.............DONE
install a windshield.......glass only, i got a new frame.
finish the cage............ or enough of it to work for now.............. i got my A pillars bent. just needs welded now.
rear tail lights need installed and wired...........................DONE
order a rear driveshaft......gonna move the axle through a cycle and measure a few spots to be sure of the length of motion required.
exhaust work, muffler > back.
install the struts........... bolt in and charge um up.
put 3 bead locks back together w/smaller anti cone rings. .......................2 down ..........1 to go.
connect the front the locker switch..
the list will grow as i recall more. but hopefully i can focus and work them off the list.
i have a few questions as well.
like what would it hurt to just weld that rear bumper to my frame ends?
should i tie the long rocker to the body armor to keep the extended edges inline vertically? (i'll post pic of this later)
