I am posting this as a warning and heads up about skid plate rust. I have a 2001 TJ that lived it’s life in South Carolina. I did a heavy inspection and the frame is rust free on the outside and inside, checked with a borescope. When I bought it I asked what things I should do and the forum gave me a great maintenance list and one member recommended pulling the skid plate, cleaning it and painting it before reinstalling with anti seize on the bolts. That was this weekend’s project.
The warning comes as I found a bunch of hidden rust that if I left it would have probably led to rusted and locked bolts and needing to replace the nutserts. Plus the rust would have spread on the frame.
Below is what I found and the process I went through to address the rust and reinstall the skid plate. Thanks to forum members for help with the process.
Rust on skid plate:
Rust on my “rust free” frame:
wire wheel and tons of elbow grease cleaning rust area:
Rusty bolts:
Added chemical rust remover as the areas around the bolt holes would not come rust free
Power washed and dried plate then painted it with Rust Oleum Rust Reformer to prep for paint. I could not get all of the rust off so I used this product
I was concerned about bolt rust so I taped off the threads and painted with rust reformer and then a layer of frame paint
Painted frame with Rust reformer after cleaning, and grinding with wire wheel
waited 24 hours and then painted everything with frame paint
Added anti seize to nut threads as well as cone area that contacts the plate:
Finished product
Rust on skid plate:
Rusty bolts:
Finished product
