B00mb00m
The Church of Cutting Brakes of Atlas-Front Digs
Not grease but a good soaking in gear lube. Which could have been present long ago.Definitely looks like it sat dry. Kind of surprising they didn't pack these with grease. My anal nature always packs the bearings, if I know it's going to sit. On the plus side, it looks like there was no moisture in there to rust parts. Since the gears look good, hopefully this will be a relatively simple fix!
Can you grind it down or will it require a machine shop?Once we pulled the race, I found some raised burrs on the outer race seating surface. I can def feel with my finger. Possibly the race did not seat fully on original install?View attachment 239760
Already knocked it down.Can you grind it down or will it require a machine shop?
Good to hear. The clock is ticking, keep workingAlready knocked it down.
We are. We are working on it right now. It's 9:45 our time. Have the races in and we're setting pinion preload.Good to hear. The clock is ticking, keep working
That damn Outer pinion bearing race was a b**** to get out.Good to hear. The clock is ticking, keep working
That was quick. Great job.Got her all put back together. Pinion preload is 23 inch pounds and backlash is .009. All we really had to change was the outer shim stack on the pinion for the preload.View attachment 239871
Didn't feel quick LOL. Getting the old races out and the new races in was the toughest part. We tried to use the original shim stacks for the pinion, but it was way too much preload.That was quick. Great job.
Perhaps, this is to address the weakness of the high pinion design used on the rear axles?the larger cones gives more surface contact across the rollers? even loading of an equal diameter?
with all the abuse they expect people to toss at um, are they just maximizing the chance of survival?
do they run a smaller bearing on the outside of a large wheel hub?
a smaller bearing on 1 side would have some kind of triangular loading where an equal diameter is a parallel loading.
is that even a thing?
Likely done that way to allow them to put the Super 60 gears in the same housing.Interesting, Currie uses a spacer to run a larger outer pinion bearing than comes on a Dana 60, which is why I had the buy another Timken HM 803146 in addition to the Dana 60 rebuild kit. (Standard Dana 60 uses a smaller outer bearing than the inner.) The outer bearing gets pressed into the spacer. The shim stack gets placed in between the spacer and the notch/step up on the pinion shaft. The shim stack thickness moves the outer bearing in or out, with respect to the inner, allowing you to adjust preload.
Aside from being restricted by whatever combination of shims you got in the kit or you have on hand, setting the preload was relatively easy. Once you have the right shim stack, pinion nut gets torqued to 240 ft lbs.
Just curious others thoughts on Currie's use of the larger inner bearing for the outer bearing. Is this necessary? Is the smaller outer Dana 60 bearing a weak point? Or is it a solution to a problem that doesn't exist? It certainly made finding a rebuild kit a little tougher. I'm assuming that there aren't a bunch of Dana 60's running around with prematurely failed/failing outer bearings.
Ah, streamlining production to be able to use same parts over various set ups. Makes sense.Likely done that way to allow them to put the Super 60 gears in the same housing.
Looks really crowded in there lol.Yep...this is my placement for the lower AR tab.View attachment 240197
