I’m replacing my winch cable on my warn 10 evo, I bought 85 feet of rope and a couple soft shackles from a company t.r.e. It has a sheath on it is this to protect the first layers from the heat of the drum?
Yep, and if you are winching out under load, you are now running a hoist and a winch is not a hoist. Stop using it like one.Unless you do a significant amount of winching out under load drum heat is not that big of an issue.
Stop already, you're been around long enough to at learn both sides due to nothing other than simply osmosis.Why replace wire for synthetic?
I defined a word, you didn't suck me into your bullshit of going over something you know, again.You bite every time . . . .
I'll have to stop fishing . . . . you can't stop biting.
Your derailment of this thread is refreshing.
