2004 LJ automatic seems to have emergency brake engaged
Hell yeah, go Air Force! Here's to hoping he didn't go aircraft maintenance!
He almost did.. ended up in ammo or munissions?.. all done now.. at trade school learning to weld so he can help dad fix stuff😂
Gimme an A! Gimme an M! Gimme another M! Gimme an O!
Hell I probably crossed paths with him, I do some of that same stuff.
He was north of salt lake, forgot the name
I just went and checked on my LJ and they have checked all the brakes and disconnect driveshafts and checked axles and have now come to conclusion it may be the transfer case or transmission?.
When driveshaft was loose they got no binding up, but when shaft wasn’t connected it wouldn’t spin ...he’s going to take transfer case down and see if anything is wrong in there.
  • Sad
Reactions: John Cooper
Jeep update.
We found out today it does not bind any at all once the vehicle is turned off. We found the temperature on the trans fluid is reading over 1000 degrees which would be a sensor problem. But all I am coming up with for a sensor is built into the valve body in the transmission. I am going to talk with Marc at the transmission shop and make sure that is correct tomorrow. If that’s the case it would be best if he did it. If it’s external we are gonna try that first! Will let you know something else tomorrow!....
This is from my auto shop Guy
Jeep update.
The 42RLE has a thermistor incorporated into the range sensor. Also: with the engine running, the L/R clutches are engaged in neutral so it won’t feel like a true neutral.
I’d be interested to find if/how this is resolved.
Is that located inside or on the outside of the trans.?
Inside, on top of the valve body.
I’ve had an issue similar to what you’ve described for about 2.5 years/20,000 miles. It often feels like something is dragging, other times everything feels normal. Early on, I went to a transmission specialist. The GM and I went for a drive and, while he agreed it felt like something was hold it back, he didn’t think it was the transmission.
After 20,000 miles, I figure something would have exploded, or at least clearly worn or failed. I’m hoping you find a solution.
Reactions: Hog
Interesting... I sure hope it is that... I’ll keep ya posted!..it does kinda come and go.. sounds like the same thing as you’ve experienced.. they’ve checked diff, brakes, transfer case, e brake.. it’s no rush so they are getting to it when then can...
I am just gonna say, I am glad @AndyG Hasn't seen or touched my Jeep yet :cool:
Reactions: Hog
So my mechanic has come to no conclusion!... gues it’s going to another mechanic
This is his reply back to me when I asked how it’s going .... someone just told me the anti/lock box could be the issue or the valve body??
  • Sad
So.. after several people getting involved still no answer yet.. the mechanic has only gotten one weird reading and that is the trans temp is reading 1000 degrees... they also said once the ignition is turned off, all 4 wheels free up.. but as soon as you start the vehicle and press the brake, it like the brakes are pressed, the trans guy didn’t think it would be anything in the trans but I’m still searching for answers.....
  • Sad
So finally got good news today, my LJ is fixed,, my mechanic finally got in touch with someone in Texas after several posts and is replacing the module on the drive side under the hood, TCM module.. the system was fighting which gear the tranny should be in basically.. so they(Texas) programmed it and in was in shipped and installed today and all is good👍🏻
Great news!!!!!
