Have a friend who has a 99 TJ, ran and was a daily driver, started doing mods, and then a few months later.. it stopped running... this is the description...
Good solid frame, 2.5l 4cyl 5spd. Shifted smooth, runs fine, compression is good. New 35” tires and wheels (less than 30mi) 4” RC lift, new PCM, new crankshaft positioning sensor, new throttle body positioning sensor, new fuel pump, new relays, new alternator, new cap and rotor, new plugs and wires, new ignition coil...all that, and she won’t start. Not getting power to the PCM, or the PDC (fuses) I can’t seem to find the gremlin. Everything else is good, no rust, straight frame, the tub is in good shape.
It cranks. Won’t turn over. Not getting spark or fuel and the computer isn’t talking to any of the sensors to get them to run. It’s gotta be a degraded wire somewhere in the harness, I’ve checked the most obvious areas and cleaned grounds but still can’t get it to turnover
The computer is brand new. I have no way of testing it other than the OBD port but it “no links”
Tires, wheels, lift, and new parts are almost worth the asking price alone. If I could get it running you could add another 4K to the price. I just don’t have the patience or time to figure out the problem.
Selling it for $3500
So, would you buy it if you had the money? Looking for advice, Thanks!
