from the perspective of a mild wheeler with shortarms whose skill level hasn't revealed the kind of problems that call for either a midarm or geometry correction, the last several pages of this thread effectively read like:
A: hey there's these ($165) geometry correction brackets
B: that's dumb, just get a ($3k) midarm it's better
I could have missed it, but I never saw Dave invite that comparison, he only seems to have defended his product against attacks that were never really reasonable considering the price point and target market for each product.
$165 is inexpensive enough that any skeptic on here with welding skills ought to be able to try it out. Hell, I'd do it if I thought I had the expertise to give useful feedback and also was dumb enough to climb into a rig with suspension link brackets that I had welded with my $90 FCAW from Harbor Freight.
The original product from Nth Degree that Dave has brought back was called the HIK AKA the Handling Improvement Kit key word handling. Its purpose was to alter the control arm angles and raise the roll center within the confines of the stock suspension. The net effect was a improved roll center height, reduction in roll steer, flatter arms that allowed a lower travel arc and an instant center location that makes the Jeep "feel" like it only has two inches of lift on it. This leads to a better handling Jeep that is much nicer to drive.
That is not to say there are not benefits to that off road as well. There is less chassis upset on climbs and increased stability in off camber situations.
You are also going to notice at no point that I used the word eliminate. Within the confines of stock length control arms there is no way that you can eliminate any bad traits you can only lessen them to a degree.
Dave did open that door and he would benefit from better explaining what the brackets can and cannot do and leave it up to the consumer if they are the right fit for them. This is the internet so there will always be fanboys and shit talkers fighting over everything given half a chance.
