Dave Kishpaugh's (Jeep West) geometry correction brackets are now available
Does a front 4" short arm pull down on the frame when torque is applied?
I don't think so. I rode around in FWD for a while waiting for my DC driveshaft to arrive. I've got a short arm lifted 3". Under acceleration, the rear would squat hard. The front didn't drop. It may be worth mentioning that I didn't have rear shocks in either. Of course, accelerating on a flat road doesn't cover all situations.
@jjvw would a 2wd Jeep climb just as well as a 4wd Jeep if no weight is on the front?
There is a difference between no weight and unloading due to weight shift. One happens before the other.
Regardless, we are still waiting for someone to explain how the front arms can transfer a force to the ground during a climb. Until that happens all we are left with is gravity and whatever the rear end does to the weight shift.
Regardless, we are still waiting for someone to explain how the front arms can transfer a force to the ground during a climb. Until that happens all we are left with is gravity and the rear end.
I thought you had it all figured out.
Reactions: D M
A mid arm will also put more weight on the front end during a climb because the rear doesn't sink under load.
Correct. Especially as compared to a typical long arm where the rear sinks and causes the front to go light during a climb.
Reactions: D M
So then I would be led to believe that better rear geometry allows the front end to do more and become more important as it will have more weight on the front during a climb.
Yes. On a climb, the rear has a lot of influence on what the front can do.
Reactions: D M
Does everyone understand this?
Yeah, i think... the sinking rear would take more weight off the front hence giving the front less traction/weight being insignificant to the pull. Having a stable rear causes the front to remain steady to have a somewhat even distribution of weight since no end is sinking or raising, thus being efficient in the pull.
Is this correct?
Reactions: jjvw
