It would pull both wheels to the side equally since the front tires are connected together by the tie rod.
That's what I thought
did you measure your old drag link and track bar vs the new equipment? How did they compare.
Mine was like spot on but after the install the alignment was slightly off so I corrected it. Now I think that is the reason my track bar failed when I turned the steering wheel to the far right, while leaving a parking space.
I am going to remeasure everything tomorrow and try to figure this out. But I do agree with your theory, but my agreement isn't worth jack-sh!t since I am a beginner in this topic.
So is toe-in. Install a suspension lift and you'll end up with more toe-in.Caster and camber are affected by a suspension lift.
Is this because of the negative camber, and that the "top" of the tire has now been rotated forward due to the axle's new position as a result of the lift? My explanation of the question sounds a bit convoluted, but I'll bet you can figure out what I mean enough to tell me if I'm correct, or not.So is toe-in. Install a suspension lift and you'll end up with more toe-in.
I think you nailed it. Axels move ya ? Bigger the liftIs this because of the negative camber, and that the "top" of the tire has now been rotated forward due to the axle's new position as a result of the lift? My explanation of the question sounds a bit convoluted, but I'll bet you can figure out what I mean enough to tell me if I'm correct, or not.![]()
Toe increases because of the inverse Y steering. Lift the Jeep and the drag link and tie rod angles both increase, pulling the wheels together. Toe does change if the caster changes, but not as much as a change in ride height. It is also worth noting that the toe will change a bit if you adjust the track bar and drag link. Basically, any change to the front suspension and steering requires adjusting the toe. And the toe fluctuates slightly as the suspension cycles.Is this because of the negative camber, and that the "top" of the tire has now been rotated forward due to the axle's new position as a result of the lift? My explanation of the question sounds a bit convoluted, but I'll bet you can figure out what I mean enough to tell me if I'm correct, or not.![]()
Okay, that makes sense. Thanks, @jjvw.Toe increases because of the inverse Y steering. Lift the Jeep and the drag link and tie rod angles both increase, pulling the wheels together. Toe does change if the caster changes, but not as much as a change in ride height. It is also worth noting that the toe will change a bit if you adjust the track bar and drag link. Basically, any change to the front suspension and steering requires adjusting the toe. And the toe fluctuates slightly as the suspension cycles.
Last question, I hope, before I try your suggestion. My total toe-in is OK right now, but when it's on the rack it shows that everything is shifted to the left (right at .20, left at 0). So, wouldn't holding the steering in center position and adjusting the drag link longer move both wheels to the right equally where the total toe can be split between both sides without affecting the .20 of total.
Taller coil springs pull on the control arms which slightly rotates the axle which reduces the caster angle which pulls on the drag link which pulls on the inverted-Y tie-rod which pulls the fronts of the tires closer together which gives more toe-in.Is this because of the negative camber, and that the "top" of the tire has now been rotated forward due to the axle's new position as a result of the lift? My explanation of the question sounds a bit convoluted, but I'll bet you can figure out what I mean enough to tell me if I'm correct, or not.![]()
So if I've got this right, the hip bone's connected to the thigh bone. The thigh bone's connected to the knee bone. The knee bone...Taller coil springs pull on the control arms which slightly rotates the axle which reduces the caster angle which pulls on the drag link which pulls on the inverted-Y tie-rod which pulls the fronts of the tires closer together which gives more toe-in.
Ha your 'hip bone's connected....' response is essentially the same as were made in previous responses to that explanation.So if I've got this right, the hip bone's connected to the thigh bone. The thigh bone's connected to the knee bone. The knee bone...
Thanks for the detailed 'splanation, Jerry!
It was the first thing that popped into my head when I saw your response.Ha your 'hip bone's connected....' response is essentially the same as were made in previous responses to that explanation.![]()
Ηey Jerry! Just to be clear, I have to:They aren't separately adjustable like they are with an IFS. One tie-rod adjusts them both simultaneously. .30 total is what you want, or .15 per side. They would only be different if the steering was turned a little to one side.
Correct. They could only be unequal with separate tie rods for the left and right sides.Ηey Jerry! Just to be clear, I have to:
Adjust (Tie-rod) the front side of my front wheels to be 1/8-1/16 closer than the rear side of my front wheels. Then re-center (drag link) my steering wheel.
If I do that the degrees of the toe are the same in each wheel, and not more on one side than the other.
Correct?
Thanks! That makes sense.Correct. They could only be unequal with separate tie rods for the left and right sides.
The 1/16”-1/8” suggestion is subjective without knowing how far in front of the steering axis you are measuring. What matters is the angle, which you can still find while using this method if you know how far from the steering axis you measure, using a little bit of trigonometry.Ηey Jerry! Just to be clear, I have to:
Correct?
It works fine for a TJ Dana 30 or front Dana 44 that is reasonably still close to the original axle design with the factory geometry for the steering.The 1/16”-1/8” suggestion is subjective without knowing how far in front of the steering axis you are measuring. What matters is the angle, which you can still find while using this method if you know how far from the steering axis you measure, using a little bit of trigonometry.
