The order has always been track bar, tie rod and then drag link. There has never been any adjustment to make on the pitman arm beyond getting it in the correct
The order has always been track bar, tie rod and then drag link. There has never been any adjustment to make on the pitman arm beyond getting it in the correct keyway for those who had reason to remove it.
yes if your steering wheel still lines up so that when it is centered, your pitman arm is directly 90 degrees perpendicular to the front axle then yes the first step is always and has always been secure the steering wheel in the center position because there is no way to center the wheel after adjusting the drag link and the tie rod. I prefer to work down the line when so is l linear and one adjustment doesn’t affect adjustment in the middle. So I do drag then tie rod. But it really doesn’t matter as the results are ultimately the same. The big issue is the drag link being used to center the wheel instead of adjusting the passenger side toe.
You can achieve the correct overall toe by simply adjusting the tire rod, however changing the drag link after achieving overall toe ( not to be cuff used with achieving driver side toe.). Would off align the combine front wheel center to the steering wheel center and that being to the gearbox center.
Hence why I do the drag link first, but if you were doing it in Chrysler order, you would secure the steering wheel to center, use the tie rod to adjust the driver side wheel to the correct toe, then drag link to adjust the passenger side wheel to the correct toe. This being properly aligned assuming that your steering wheel center is still the same as gearbox center. The whole shafts part boiled down to almost every gmc, TJ, Xj I have worked on has had some one at some point screw up the steering wheel to gearbox center points. If both are not centered at the same time you have to work your way down the steering shafts and connections until you find out why. My second point is if the gearbox’s center point is not the same as the combined front wheel center point you loose the static hydraulic pressure that is equally distributed in both sides of the turning gear. This means it feels as loose with the engine running as it does when the engine is off. This also means the gears absorb all the impact while driving instead of being buffered by hydraulic pressure. This further means people reduce the gearbox lash with just increases the impact the gears receive.
The overall all point is, to center the steering wheel the left and right toe have to set to wheel not the other way around. The easy way, drag link to center the steering wheel, just cost you extra money in long run and responsiveness in the short run.
I probably won’t bother answering anymore unless I see a reason too. I explained the best I can. I am sorry if a confused anyone. I like most engineers visualize the mechanics of it, but not so good at expressing it.
All I can suggest is forget both the misconception and what I have said, check that when your steering wheel is centered that your gearbox is centered. Strap the steering wheel dead center. Then do your alignment. Once you have both wheels correctly toed, unstrap the wheel and go for a spin. That way it’s no longer me trying to convince you the results speak for themselves.
