Steering wheel center and toe adjustment
OldGuyOldJeep
OldGuyOldJeep
GA
to whom ever I gave two reasons why pitman wouldn’t be strait back when gear box is centered, I totally for the 3rd reason. Pitman arm mismatched. The key the stock 5203887 pitman are something like 12.5 off center which lines up wi the stock 6530? I think I am remembering that right but if the part store gave you the “alternative” box 8413, 8412, 6532 etc.. there are a ton. The pitman arm will fit them, but the center offset is different on each part number so it throws the arm off by the difference in offset. I actually have the 108 one from the Durango in mine, and had to change pitman arms to the 8347 to match offset. 108 is great btw if you do a lot of deep mud, only 3 turns stop to stop. My make wheel shifting easy.
hosejockey61
FAFO
Parker, CO
It’s the middle of the day, is there day drankin’ goin on?
That would be a yes.... Water of course😂
