Last week I picked up my jeep following a regear, and now I'm getting constant vibrations (not harmonic) that start around 68 MPH and intensify as I get up to 75 MPH (I haven't gone over that). Hoping that the brain trust here can provide some advice. Here is what I can tell you:
Questions:
- It's a '98 on H&R 1" springs (I initially got 1.5" out of it). No other lifts. No MML.
- Control arms are brand new OEM style replacements (Crown)
- I do have cam bolts on the front, and they are maxed out as long as they'll go
- I used to have a small harmonic vibration in the high 60's MPH, but after installing my Gobi rack, that went away. My thought was that the drive line angles came into their comfort zone with the added weight. It was quite smooth at 75 MPH before the regear.
- The regear was done by a reputable shop that does a lot of Jeep work
- I went from 3.07 to 4.10 with an Eaton E-Locker in the front and a Detroit True-Trac in the rear (Dana 30-Dana 35).
- Since the vibes started, here is what I've done to troubleshoot:
- I verified the lug nuts were torqued correctly (they were all good)
- Lowered my transfer case about 1/2" (no change to vibes)
- Removed front driveshaft (vibes were completely gone after doing this)
- Thinking something may have been out of spec with the front driveshaft (I just rebuilt it a couple months ago with the Denny's kit) I took it to a driveline shop to test for balance and see if it was bent. It was out of balance, so they removed the factory weights and rebalanced it. I installed it last night and on the test drive, the vibes were still there, although it seemed like they may have started a couple mph later. Still strong at 75 MPH though.
- Here are my rear driveline angles:
- Rear Pinion Oper angle = 1.0*
- Rear TC Oper Angle = 0.4*
- Here are my front driveline angles:
- Front Pinion Oper angle = 1.5*
- Front TC Oper Angle = 2.5*
Questions:
- Shouldn't the front pinion be parallel to the front shaft? Seems like mine is off, but I don't get why - it's only an 1.5" lift, I'm really surprised I'm having these kinds of issues.
- Thoughts on the rear shaft angles?
- Is there anything else to check that I'm not considering? I intend to take it back to the shop at 800 miles for them to check the pattern anyway, so if I can't figure out anything by then, I'll have them check deeper too.
