Hello new to the site, im sure I'll find the answer with some navigation but I have an '02 Sahara with 4.0 and '37 was wondering what lockers would give me best bang with a $3k budget. Would be used as daily driver as well
I assumed they were 30 in the front and 35 in the back butt but does it say on the differential coverSince you have a Sahara hopefully your TJ has a Dana 44 instead of the Dana 35.
IF by some chance you have a Dana 35; then I would recommend against the installation of a locker.
IF you do have the Dana 44 as you should in a Sahara; then as Chris posted above.... you should consider a selectable locker such as ARB or Eaton...
Take a look at these and compare what you have.I assumed they were 30 in the front and 35 in the back butt but does it say on the differential cover
YES....Turns out I've got 44's front and back and 35's is that a safe combo?
Has your front axle been swapped?Turns out I've got 44's front and back and 35's is that a safe combo?
Can’t be it’s an 02So you have a stealth Rubicon?
If so you just scored big...
I had to edit my post tooSo you have a stealth Rubicon?
Edit: Never mind I'm an idiot
The Sahara came with optional 44'sHas your front axle been swapped?
Only the rear. The front is a Dana 30 unless it is a Rubicon (2003-2006 only) or has been swapped aftermarket.The Sahara came with optional 44's
