I have a 2006 LJ with a 4in Currie/Savvy lift. I went to install and check the rear bump stops and found that the rear trackbar Johnny joint is bottoming out on the axle side bracket. This is limiting the amount the axle can droop on the drivers side. Is this normal?
I have reached out to Currie and have got conflicting answers. When I initially called to confirm what trackbar was needed before purchasing, I was told I need the track bar and axle side bracket. Yesterday I was told "With a 4 inch lift you most likely don’t need the track bar relocation bracket and would run just our adjustable track bar. ..I know at least on JK’s that the relocation bracket is really only if you are using the stock track bar or one that isn’t adjustable." Looking at the install instructions, I see one line that says the bracket may not be required for LJs. For people running the Currie/Rockjock trackbar on LJs, are you using the bracket?
