Some use a press fit and some are threaded in with a set screw to hold itAre you sure all of those require a press to install?
Great now the Johnny Joint KGB is going to wipe you off the internet and show up at your house if you say things like that.Now you sound like Joe Biden peddling vaccines
No, you're just being hyper critical of the MC control arm joint, that by the way surpasses the OEM design in your targeted area of concern (Axle wrap) SMH, purely based on the fact that you don't like MC.No, it doesn't because you are ignoring too much of what was said.
You're still doing it.No, you're just being hyper critical of the MC control arm joint, that by the way surpasses the OEM design in your targeted area of concern (Axle wrap) SMH, purely based on the fact that you don't like MC.
I'll say it again, no one has said that MC is superior to JJ in its ability to take a pounding, It is however more appealing to plenty of people based on it's ability to survive moderate off road use without maintenance, unlike JJ!
Enlighten me then oh all knowing one!!! Drop some JJ wisdom on all of the non-believers. Prove all the MC owners in the world are nothing but morons lead astray by their stupidity!!!You're still doing it.
You heard it here, there’s no maintenance necessary at all. He’s just a set it and forget it kind of guy, maybe like @reddvltjYou're still doing it.
This to me is one of the bigger problems with the MC joints. When I set my pinion angle I had to dial it in with an 1/8 of a turn on my uppers to get it to not vibe. I don't remember exactly what the shank on the mid arm JJ's is, I'm going to guess 1 1/4 - 12 thread on the shank, so in a straight line that would be .083" of movement, but it's even less than that considering the uppers are triangulated.I'm not so sure about that. Again, I've seen the axle wrap from MC bushings. That can easily turn into driveshaft vibes from the rising pinion. Especially on the highway at higher speeds. This excessively moving pinion makes it really difficult to set the pinion angles. And I've also seen front end shudders and a general wallowiness that disappeared after a switch to JJs from MC.
We all know how easy it is to dismiss and excuse these things as a Jeep thing. And most don't know any better.
So, I ask again, why is recommending the lesser product acceptable?
What’s the snap ring used for? The far end of the housing (non-threaded end)?And the one that made me switch to MC, the RE Super Flex Joint…the zerk doesn’t work worth a dam on it either.
YepWhat’s the snap ring used for? The far end of the housing (non-threaded end)?
I figure this thread is so far gone I may as well carry on the theme.Hahahahahahahahahahahaha
They were the first ones to use that designSeems a little odd, but maybe it’s a patent thing.
I smell a repaint comingI figure thus thread is so far gone I may as well carry on the theme.
@smurf make a build thread so I can see more photos of that jeep. The blue you have is by far my my favorite on a jeep. To this day I've only seen 3 in person.
They’ve been around a few years longer than JJ’sSeems a little odd, but maybe it’s a patent thing.
I was telling Mike I should do it when I was painting the armor. Now it'd be so much work given I'd need to paint the jeep then the corner armor, and all the doors.They were the first ones to use that design
It’s a very striking blue is it electric blue?I was telling Mike I should do it when I was painting the armor. Now it'd be so much work given I'd need to paint the jeep then the corner armor, and all the doors.
But........ I'm not ruling it out. I remember in 2019 when @JMT and I were on elephant hill near moab staring at a blue jeep. Love that color.
I believe it was Intense Blue Pearl. Looks very similar to the hydro blue on the JL.It’s a very striking blue is it electric blue?
