I changed my wheel seals in my front Dana 30 this weekend and both sides are already leaking worse than what they were. Any ideas? I used a seal press tool to set the seals back flush. Should I have kept going till it stopped?
How full was the diff when you pulled the shafts out?I changed my wheel seals in my front Dana 30 this weekend and both sides are already leaking worse than what they were. Any ideas? I used a seal press tool to set the seals back flush. Should I have kept going till it stopped?
X2. what brand seals did you use and what part #.What is the gear lube level inside the differential ?
There may be fluid trapped inside the axle tube during the seal replacements....
Diff was full. I just had a small leak before i replaced the seals.How full was the diff when you pulled the shafts out?
I cleaned the axle tubes when I changed the seals.What is the gear lube level inside the differential ?
I used Mopar seals part number 5014852AB. I just bought national seals now to go back in. Didn't want to wait on the shipping of mopar seals again.X2. what brand seals did you use and what part #.
Since you cleaned the axle tubes and the gear lube is at the appropriate level; did you check the axle surface where the seal meets the axle surface ?I cleaned the axle tubes when I changed the seals.
His issue is on the front, Jerry. I think you are referring to the rear.The axle retainer bracket seats them at the correct depth. I have had to resort to smearing a thin layer of RTV made for gear lube, like Mopar RTV or Permatex Gear Lube RTV around the outer sealing edge of the seal but @mrblaine can give you the name/number of a good seal that works well there. I don't believe he has any problems with it sealing.
I believe that part # is for dana 44 axle.I used Mopar seals part number 5014852AB. I just bought national seals now to go back in. Didn't want to wait on the shipping of mopar seals again.
Shit lol. Yep I had read that before, that's what I get for trying to juggle two balls at once.His issue is on the front, Jerry. I think you are referring to the rear.
It does actually work in the TJ Rubicon model. Those are the same seals I have in mine.That part number is good for a JK, not a TJ.
That's the ones I just bought so hopefully these work!National part # should be 710068 as long as its a dana 30 front axle.
