How do I find replacement lower control arm bushings?
Rick2004LJ
Texas
I need Control Arm Bushings all around, but have no idea make/model of the adjustable control arms I have (lift done by PO). Are replacements bushings universal or make/model specific? If specific any way to determine what I have or measure current bushings to find replacement?
TIA
Looks like from old thread the fronts were rough country and maybe rears stock?
Would it be good to just replace the control arms?
The front uppers and lowers are adjustable aftermarket. The rear uppers are stock and lowers are aftermarket fixed.
There are some replacement bushings described as "OEM Clevite style bushings" - is that what I have?
If they are oem they would only work on the rear uppers which are stock.
Pictures would be way more helpful. 🤫
Reactions: 707kevin
Hopefully this helps a little.
If you keep the OEM arms OEM - don't bother replacing the bushings - just buy a complete new arm with bushings.
The front uppers axle side need to be pressed into the axle - they are different.
Reactions: TJ Starting
