You are absolutely correct, I can't believe I missed that considering I took the connectors off the tcaseThere is a t case position switch on top of the t case, above the front output. That is where that 2 pin connector goes. I know it goes there because the wire colors are black and black/red.
I do see thatYou need to find this connector which is somewhere on the harness, in front of that t case position pigtail. Unless you unhooked it, it should have the neutral safety switch pigtail plugged into it.
Thank you, I can't see well enough tonight but I'm going to try this in the morning and I will report back. I think you may have just saved me a giant headacheOnce you find that 4 pin connector, unhook the neutral safety switch pigtail, go over to your manual harness and grab the manual pigtail which has that same 2 pin connector on it like the t case uses. plug it in, should start right up.
I'm thinking I just have the worst luck ever. Literally haven't touched the tj since last night went out there and now back to no guages(except odometer like before), no fuel pump, and no obd2... Which makes no sense at all
Yeah all that looks good, I'm sadly starting to think I've gone over my head here and I'm considering having it towed as I'm going to need it for this winter.Check fuses and voltageon your battery. Then if the battery is good disconnect it and unplug and check all the pins in the PCM to see if any are bent.
Then plug it back in and reconnect your battery. Then see what happens.
The jeep demands blood apparently. I've already sacrificed several thousand dollars in the past few months
My completely dumb and probably not possible theory is that since that pcm came out of a Rubicon it had skid and I locked it up. I'm wondering if that's the case if it could be reprogrammed for non-skid and to my vin#@Wranglerfix I think can.
I can test it for you. What year is it?Does anyone know if a jeep dealership can test a pcm?
pcm is from an 03 rubiconI can test it for you. What year is it?
this is how I feel about this entire situation lol. all the wiring is taken care of and at least and the jeep wants to crank. All I lack is (hopefully) a pcm and a 5 speed trans mountI don't know enough about Skim to help you out there.
At least she cranks now. O'Reillys can get me the pcm I need for $180 but it'll take two weeksBut you're getting CLOSE and that is what matters. Don't lose faith. You'll get it.
