I'm not running the fuel cell....I'm running their tank. Its designed to accept the TJ fuel pump. Plug and play. Only issues that I had were making the emissions work but I got that figured out. Here is a post that details everything: Gas Tank Post
OK. Their fuel cell has the cutout for the stock fuel pump/sender but then you still have to mount it.
Their tank isn't large enough for me as I want a 20 gallon or as close as possible to that.
Got the shock mounts welded up and fixed the spot I'd cut a little bit deep with the plasma cutter when I was taking the old mounts off.
Can't even tell where that spot was.
And my welds are looking better. Finally figuring out this new welder.
OK the upper shock mounts and gussets are welded in.
Got the bottoms done without setting myself on fire 🔥 too.
And the tie into the frame slots I'd cut worked nicely.
I'm just going to keep working towards having the Jeep finished and once my savings account recovers from buying the tires I'll get the rear axle fixed.
Hopefully I can have it fixed before I'm done with everything else on the Jeep.
Did some measurements today using the information on GenRight's website for their tanks and it looks like I can fit one in the back. Once the rear axle is back under the Jeep I can do some final measuring and verify.
Did you hire a professional/certified welder? Dang. Looking good.
For anyone interested here is more information on the Jantz Jana 76 and the other kits he offers also. While I DON'T want to have to spend this money I'm stoked about doing this to my axle. And at some point I'd love to build a HP44/60 Hybrd with a Jana54 kit.
https://www.pirate4x4.com/threads/jana-76-54.914583/
https://www.pirate4x4.com/threads/jana-76-tm-or-how-to-install-70s-in-your-60.946421/
https://www.pirate4x4.com/threads/jana-cover-girdles™-or-how-to-keep-10-lbs-in-a-5-pound-box.958047/
I figured since I was this far along with everything and there wasn't anything stopping me I'd weld the inside of the shock towers. I pulled all the body mount bolts except for the two front ones.
I jacked the body up off the frame.
Then welded up the back side of the mounts and gussets.
I had some blocks of wood stuffed between the body and frame for a little added safety.
Great progress Rick.
Thanks Jeff.
I don't know that it was needed to weld the inside but since I was in a spot where it was fairly easy to raise it up I figured why not.
Going to pickup the driveshafts today and then I'll get started on the exhaust.
I knew it was going to be CLOSE and I wasn't disappointed.
I haven't seen the front driveshaft installed forever.
This is at full droop on the passenger side and full stuff on the drivers side.
It's just touching the Savvy midarm tower. Easy fix.
It clears and that is what I wanted. Not by a LOT but I think it'll be OK.
It's hard as heck to get a good angle on this.
Tomorrow I'm gunna dig out my manual on my welder and start figuring out how to use the Tig welder. The exhaust is all stainless steel so I bought a small tank and it's filled with what I need for stainless steel & I have rod for it also. So I'll cut some small pieces and practice and then start on the exhaust.
Tri-mix?
I honestly don't remember. I told the guy at OxArc what I was doing and he said this is what you need.
Tri-mix is what I used to MIG my exhaust. I don’t know if it’s different for TIG. I did not back purge - but I should have. The welds sugar a lot on the inside if you don’t, as I understand it.
