@COYOTE83, I know you didn't solicit advice, so I apologize if you've already considered what I'm about to say and made your own decision. I would suggest mounting at least one tire snubber below the tailgate. I don't know if all years of TJs had a snubber down there in the middle, but it does look like you have a hole for one there (mine had one there when I bought it). When I put my Moryde system on, I carefully set the length of that lower snubber so that it put just a smidge of pressure on the tire. That way, as you bounce down the trail, the tire doesn't flex the tailgate as much because the bottom snubber works with the latch pin to stabilize the tailgate/tire assembly. I know that there have been a few posts about tailgates cracking, even with the Moryde kit, so I wanted to do what I could to prevent it. I put some pics in Post 11 in this thread:
https://wranglertjforum.com/threads...-tire-carrier-dimension-mounting-depth.57374/
Again, you didn't ask for advice, so just ignore me if you've gone your way for good reason.
