"Pacing myself" build
How about my soul?
Bob needs some tlc. Engine light is still on, (p0432), bank 2 catalyst efficiency fail. Front diff cover is seeping. Rear pinion seal seeping. HVAC smells like dust after the heater core incident. Blower motor needs removed and blown out. Wish I did that while it was out, duh!
The KO2's are getting close to the end. Other than that everything's peaches.
Put the hard top back on after almost 2 years without.
Also did some routine checks. Front diff cover was leaking. All the button head Allens holding the cover guard were finger tight loose. Tightened them, but the RTV may be compromised. Got a lube locker gasket ready to go if it continues leaking.
