This is exactly what I need to do .. I have a set of lights from @mrblaine and that stupid Exogate is preventing me from putting these lights on. I did light them up on my workbench though .. they are beautiful.
Us in the desert southwest, may have our 2nd wet winter in a row. Still aint washed off last year's mess.
Not without trimming the plate.
Ok. Trim the plate seems easy enough. What about the oversized Morryde hinge?
can’t see where you cut. Also. That rear bumper/Crossmember. Barnes?
For those that don't have the factory connector plug on the jeep side, it looks like @mrblaine now has those connectors available on the website. Also works for those with 97 TJs @macleanflood
These connectors are not easy to find, don't think I have seen them available just by themselves anywhere else. It's awesome how much thought has went into these LED tail lights to provide as clean and as complete a solution as possible.
https://blackmagicbrakes.com/ols/pr...cense-plate-light-and-bracket-lcn-plt-rlc-lcn
For my exogate carrier I used an aluminum spacer and only had to grind the radius edge a little. @psrivats I have some leftover to make another spacer.
We all do that, we just don't tell people.Man, what great quality for his hard work. I had to look and fondle the parts before the install.
Just recieved my tail lights and relocation plate. Man, what great quality for his hard work. I had to look and fondle the parts before the install.
I did have a slight problem, but @mrblaine helped me fix it right away.
So, great Tech support too…
Thanks!!!
Whoa!
I was wondering what was up when I noticed the new @mrblaine avatar photo. And voilà, new item on the BMB website!
Delrin is such a good material choice for these and it will be a fantastic option for the budget conscious folks that still want a great tail light. And I don't think I have ever seen Delrin/Acetal used in this application before, such a cool idea and fully unique in the way only Blaine can do it.
https://blackmagicbrakes.com/ols/products/coming-soon-led-tail-lights-acetal-housing
Acetal, is that the same material as the body lift kits?
