Hey doing some research on upgrading my fuel tank. Seems like I’m only getting about 12gal out of my tank and was looking online at getting a 19 gal. Does anyone know all the parts I need to purchase in order to go through with this?
That is very strange. I cant recall the exact year 98 or 99. The completey stopped using the 15 gallon tank. Isn't there a ball valve that can go bad in the newer 2000+ tanks @ChrisI’ve dropped my tank and cleaned it out completely and then filled it up from empty all got into it was 2x 5 gal gas tanks and then a 2.5 gal gas tank and there was left over in the 2.5
I was thinking about this valve
Even though the guy calls it a Cherokee
Only completely stripped very basic TJs ever came with the smallest 15 gallon tank, by far most TJs came with the 19 gallon tank. Know this... the TJ's gas gauge is notoriously inaccurate and overly conservative, it generally always indicates substantially less gas than is actually in the tank. Even my Low Fuel light comes on when I still have approximately 4 gallons left in my tank. I never fill up until it's down at the very bottom line and even then my tank still has several gallons left.Hey doing some research on upgrading my fuel tank. Seems like I’m only getting about 12 gal out of my tank and was looking online at getting a 19 gal. Does anyone know all the parts I need to purchase in order to go through with this?
The stock tank is plastic.Don't mean to hijack, but on the subject of TJ fuel tanks, can someone tell me if the stock/OEM tank is metal/steel or plastic? I noticed my tank is plastic and was curious if it has been replaced. Thank you!
