I've been loving having the harbor freight press. I will be picking up the Swag press break kit for it.
I saw this video this morning on it, would be nice to have.
Ya the swag break looks super useful. I want to get that and the portaband table.
Got out to my local park today. Soooo good. Belly clearance is noticeably better. I almost had to try to hit it. In fact the time I drug it I was also dragging driveshaft. Made an obstacle I couldn't last time due to bellying out.
Cough @Chris picture of the month cough
They look good after you got 'em cleaned up and repainted. The paint was chipping pretty bad on them, so whatever you did, good job!Got my 98GC hood vents in this weekend that I got from @Squatch. More and more j just want things to be a bit different than the normal. So I couldn't bring myself to buy a PS hood Louvre. I also like that the GC vents have pans considering the location I wanted to place the vents would drip on my TCM and fusebox.
Whelp, the first one was quite the learning experience. I massively fawked up and flipped my homemade template half way through. I salvaged and did things right on the second one. It went so smooth and easy and I even notches the pan and recreated water channels to keep most water off the TCM.
My positioning may seem a little strange but it was primarily due to extremely tight clearances to the hood from my fusebox and my TCM.
I also wanted to follow the heat map that was generated long time ago for tj hood heat which showed outside back as high heat locations.
The color is a Rust-Oleum hammer finish rattle can. I really like how it pairs with the OEM desert khaki. I am probably going to repaint my rear fenders rockers and bumper in this instead of black.
I moved the vents as far aft as possible and as far outboard as possible and put the lowest bolt right next to the hood support and right at the start of the hood bend. From there just aligned the angle of the vent to parallel the hood lines.
Thanks, ya sanded them up then primer / paint and clear from rattle can.They look good after you got 'em cleaned up and repainted. The paint was chipping pretty bad on them, so whatever you did, good job!
Removing that hood insulation might help some too.I got the new silicone parts to fix up my intake today. I previously the cone sitting straight in line with the tube but noticed it had been hitting the insulation on hood and I was getting a whistle when it was hot and it was trying to suck in the insulation. Figured the whistle was likely due to air filter setup. So I got the the 45deg and cut the tube down some more and was able to get the cone down by the back of the coilover hoop.
Test drive went great and I could feel the heat pouring out of the hood vents so hope that helps and no more heat soak rough startups.
I considered it. I should be good now and Id like to keep any fire protection I can.Removing that hood insulation might help some too.
Is that what it is for? I figured it was for sound.I considered it. I should be good now and Id like to keep any fire protection I can.
Cringe. It hasn't been delivered yet. Temp-sender arrives on Thursday so possibly a weekend project... I hope... Depending on what needs fixing.I'm just waiting for the awesome trans pan install write-up.
Where is that? I'm thinking the speedway hill from the ferry terminal all the way up. It's perfect 3rd gear torque converter open speed. Other than that the actual best test is forest roads 4-hi up STEEP grades at 30mph.Dutch hill?
I am but the ferry hill is the only hill long and steady enough where i've managed to get my old temp gauge (mounted on aux filter) to go over 220F.By the ferry? I thought you were in Snoho bud, my bad
