X2, just lower the fan shroud an inch by drilling new 1" lower mounting holes in it, no need for a MML. You may or may not need a transfer case relocation bracket to level the shifter mechanism which is mounted between the transfer case which stays at the same height and body which gets raised up an inch. My '97 TJ's transfer case shifter worked fine after installing my 1" body lift but not all are so fortunate. It seems like I also had to install a short extension pipe between the gas filler hose and the gas cap assembly which came in my Performance Accessories 1" BL kit.No it is not true. Unless you do not have those things. You will need to move your radiator shroud tp fit where the fan ends up. If you do not have one, get one! You may need to re-adjust your linkages to work correctly.
MML is a big reason to do a BL, in my opinion. I have a bracket that removes the body tub mount for the t/c shifter and it works quite well.Agreed. To do it properly you'll need a MML (motor mount lift) and you'll either need to re-adjust your transferase linkages or get an aftermarket linkage (which in my opinion is way better than the stock one).
There's no need to do a body lift just because a MML was installed. A MML lifts the fan up so it's an inch higher but you only need to raise the fan shroud an inch (drill new 1" lower mounting holes in it) to compensate, you don't need to install a body lift to do that.MML is a big reason to do a BL, in my opinion. .
I suspect the reason we never encounter the #1 oil issue is we rarely do a MML and BL without raising the belly at the same time.
Not me, AOR.
That guy at Rough Country is clueless, a MML is definitely not required after installing a body lift.well i see this is quiet a bit older post but i just wanted to add something i just heard from Rough Country. I am thinking about adding a 1.25 body lift to my 97 tj that already has a 4" suspension lift. I just got off the chat line with Rough Country and they tell me i need to do a MML if i install the 1.25 body lift. I know thats just one mans opinion, but figured he would be a good person to ask.
So since yall commented to this post have you changed you mind about the MML along with a body lift? I want to do the body lift for just a little more distance between the tire and fender well. So are there several reasons to do a MML ??
You only need to lower the fan shroud an inch so it lines up with the factory height engine fan. Installing a 1" body lift raises the radiator and thus its fan shroud 1". Drilling new mounting holes 1" higher in the fan shroud will allow you to lower it back down so it properly clears the engine fan.
Jerry, does the MML actually help with other things like pinion angle, transfer and shifter lever height?
Chris did you mean to say " The MML is going to position the rear of the motor and the transmission in a downward angle" ??
