1997 Fuel Tank Cracked
Brannon
Seeking Overland Adventures
El Paso. TX
My tank has been leaking or over a decade when topped off. I think that it is leaking from the plastic nut or the that part of tank that holds the fuel pump in place. if I trickle in the gas the filler hose never over fills and the fuel just drips from the bottom. I am not able to drop the tank with out breaking bolts (too much rust). I am not able to find an affordable 19 gallon tank anywhere. I would like to keep the parts prices below $250. Do you have any recommendations?
Reactions: Wheeler
I shopped around on Facebook Marketplace until I found a tank and skid plate for $100. As my 97SE was missing most of the bolts I went ahead and replaced all of them. It seems daunting but it’s not as horrible as it looks.
I took pictures during the process and replaced all the bolts with stainless steel hardware. If it helps you can take a look at my build thread. It’s two wards the end.
https://wranglertjforum.com/threads/wheeler’s-project-that-he-didn’t-want….56574/
Need to get on Craigslist and FB Marketplace and looks for Ad's like this..
https://elpaso.craigslist.org/pts/d/el-paso-2002-jeep-wrangler-tj-parts/7458018011.html
Also check out Daveys Jeeps and do a parts request as not everything is listed.
https://daveysjeeps.com/
I have 4 or 5 good tanks I would almost give you if you were local..there has to be someone local that parts jeeps..gas tanks aren't something that sells easily
