1998 TJ 4.0 5-speed shitbox build
CTJeep
Connecticut
Here’s my shit box build guys: this is all the work I’ve done so far:
FRAME Rebuilt with adjustable perches
Dana 44 Rear axle Installed With new backing plates
Dana 30 Front axle installed
Now geared at 3.73
New clutch,
Axle shaft U joints,
Brake cables/ hoses
upper and lower ball joints,
brake rotors and ceramic pads,
Drop arm to correct lift that it came with
NEXT STEPS:
ripped the dash out as previous owner spray painted the whole dash red
I have OEM dash from junkyard that will be installing
Need to fix wiring, Radio/fuses/ headlights
Floor pants
Body rust
Reactions: mxz800 and Chris
Holy shit! That’s a lot of stuff to fix. I commend you for taking on the project. What did you pay for it?
The previous owner really did it with that stupid grille and all the red paint everywhere 🤣
Now geared at 3.73
New clutch,
Brake cables/ hoses
NEXT STEPS:
Floor pants
Body rust
It's already looking a whole lot better.
I paid 2500 , really worth 500$ I overpaid because I was dumb and eager to get a jeep but here I am dumping money into it
Today 1/1/21 I ripped the backseat out and most of the carpet in the back. I tried for hours to remove my passenger seat but could not. I cannot get my passenger seat to rock forward to reveal the torx bolt and the 13mm bolt . As you can see there’s rust in the back of my tub. Going to continue moving forward to see what I can get done . Probably going to remove door panels next because as showed before owner painted red 🤦🏽‍♂️ And going to change exterior door handles to some black ones I’ve purchased
Also don’t mind garbage I have to bring to the dump.
I did a stupid thing when I bought my 2001 by not checking the frame like I should've done. I owned it for 5 years before the rust won. My 2004 is solid as a rock.
Reactions: CTJeep
See I did the same damn thing but I’m working the best I can to make sure I can get this thing spotless
