R R6Towing New Member Joined Mar 9, 2019 Messages 5 Location Seabeck, WA Feb 15, 2020 #1 I'm replacing my TPS on my throttle body. I took a torch to the screw because they wouldn't come out. And I notice a orangeish liquid coming out around the shaft, it dried hard. Did I just melt a gasket or something or is this some of the loctite?
TJ4Jim TJ Expert Lifetime Supporting Member Joined Dec 9, 2015 Messages 3,893 Location Brookings, Oregon Feb 15, 2020 #2 You can remove the screws from the butterfly valve and slide the shaft out of the TB for inspection, cleaning and lubrication.
OP R R6Towing New Member Joined Mar 9, 2019 Messages 5 Location Seabeck, WA Feb 15, 2020 #3 I can replace those nylon bushings in between the shaft bearing with orings?
TJ4Jim TJ Expert Lifetime Supporting Member Joined Dec 9, 2015 Messages 3,893 Location Brookings, Oregon Feb 15, 2020 #4 R6Towing said: I can replace those nylon bushings in between the shaft bearing with orings? Click to expand... I do not recall any nylon bushings in there, just remove the shaft and inspect it.
hdbiker1 Member Joined Dec 16, 2018 Messages 42 Location Kelso, Wa. Feb 15, 2020 #5 Is your throttle shaft loose? Check this out, it might help.
OP R R6Towing New Member Joined Mar 9, 2019 Messages 5 Location Seabeck, WA Feb 15, 2020 #6 TJ4Jim said: I do not recall any nylon bushings in there, just remove the shaft and inspect it. Click to expand...
OP R R6Towing New Member Joined Mar 9, 2019 Messages 5 Location Seabeck, WA Feb 15, 2020 #7 hdbiker1 said: Is your throttle shaft loose? Check this out, it might help. Click to expand... No, my shaft wasn't loose. I just melted the bushing with a torch when trying to take out my TPS screws. I'm kinda worried about putting orings in.
MikeE024 TJ Addict Supporting Member Joined Mar 29, 2021 Messages 2,468 Location Tucson Jan 26, 2023 #8 TJ4Jim said: You can remove the screws from the butterfly valve and slide the shaft out of the TB for inspection, cleaning and lubrication. Click to expand... Hey @TJ4Jim have you ever replaced/modified the bushings on a 4.0L TB?
