Since you've cleaned the throttle body and the idle is better without the air intake tube, I would suggest checking for any vacuum leaks around the intake system. Even small leaks can cause irregular idle because they introduce extra air that the engine can’t compensate for. A smoke tester such as this one is perfect for that: https://www.amazon.com/gp/product/B0DNS1GT23/?tag=wranglerorg-20
Also, if you haven't already, I would consider cleaning or replacing your IAC (Idle Air Control) valve. A faulty IAC can cause erratic idle issues as well. Make sure the electrical connections are solid and see if there are any error codes if you have a code reader.
It's also worth inspecting the condition of the MAP sensor; a dirty or failing MAP sensor can cause similar problems as well.
Keep us updated on what you find! You're definitely on the right track.
Thanks for the help! I went ahead and ordered the smoke test machine in the link. I guess we’re going to go take it for a cruise anyway and hope for the best, just hoping it doesn’t leave us stranded lol.
