So after filling my my transmission with water and mud I think my trans is pretty much dead. After pulling myself out of the mud hole the trans started whining pretty bad. I limped her of the trail and just as I got on the pavement she started blowing trans fluid out everywhere and the trans was just completely slipping. I called AAA and after waiting an hour they called me back and said "Sorry we don't have any trucks in your area and we are not sure if/when I can be picked up". So I went for broke... I fired the jeep back up, poured the last bottle of trans fluid in and somehow got all the way back home (60 miles away). It was a super sketchy ride and the trans was not acting right at all. The next morning I flushed the trans and got all the pretty pink fluid out. The whine went away and it seemed as though it was engaging pretty well so I took it for a spin.
Now this is where things got a little odd. if I have the trans in Drive it slips terribly off the line and doesn't quite shift into the gears correctly. But if I put the shifter into 1st and then back to drive before leaving a stop everything works as it should, shifting and down shifting right, lock up engaging and disengaging as expected. But as soon as I stop and try to leave the light in Drive it slips really bad and shifts like crap.
At this point I really just want to rebuild the damn thing so I am not worried every time I go out, plus I .need to relocate the breather so I don't do this crap again. Anyone have advice on rebuilding a 32rh? Are there any upgrades I can do to make the trans a little tougher (not that it was the trans fault in the first place) Also I am looking for a rebuild guide of some kind. I did a bit of searching but these damn 32rh's are tough SOB's so not much information out there.
Adding resources as I find them:
https://www.wittrans.com/parts?type=A904 (30RH-32RH)§ion=90_planethttps://www.allpar.com/threads/torq...sion-major-components.230004/#post-1085224102
This is actually a really good series. There are a lot of videos but the guy takes it nice and slow to really show every step. (This is an A904 from a mid 70's car but the internals are almost exactly the same.)
REBUILD KIT:
https://www.oregonperformancetransmission.com/product/OPT-A904-RBHP.htmlThis HP transmission overhaul kit comes with the following rebuild parts:
REBUILD KIT:
- Raybestos HP Red friction clutch plates
- Alto black Kolene steel plates
- Kevlar intermediate kickdown band
- Internal fluid filter
- Pump bushing
- Output shaft bushing
- All rubber clutch piston seals
- All paper gaskets
- All O-rings
- All metal clad seals
- Teflon and steel sealing rings
- Transgo TF-2 shift kit
