3rd position on fan knob dead
Dan Westphal
West Chester, PA 19382, United States
Lost the 3rd position on my fan knob for the cabin air. Am being told I need a resistor. Where is a good place to pick one up. AutoZone didn't have it. Amazon? Anyone have the part number I'm looking for? Thanks guys!
Sent from my SM-N915V using Tapatalk
We need to know what model year TJ you have to recommend the correct resistor pack. Please complete your Profile. The resistor pack in the above link is only for newer TJs, older TJs require a different type.
It may be a bad switch. Usually with a bad resistor, only high fan works.
Individual resistors in a resistor pack can and do go bad leaving just one fan speed inoperative. A resistor pack is made up with 3 individual resistors so if just one resistor goes bad, just that one speed disappears.
Of course it could also be a bad switch or on an older TJ, the wiring could have started going bad too.
The usual root cause of fan speed problems is a fan motor that is going bad. When it starts going bad, its windings have begun shorting out which causes the fan to start drawing excessive current. That is the usual root cause of things like bad fan switches, resistor packs, and melted wiring.
So this morning I turned on the jeep to warm it up and went back inside. When I came back out the fan was off. None of the positions work. I'll start with the fan switch and move on from there. Quadratec is right down the road so I can get the part this afternoon.
