LONGJP2 TJ Expert Lifetime Supporting Member Joined Aug 11, 2019 Messages 5,852 Location S. Illinois Aug 20, 2024 #21 madridalejandro said: Did you end up getting this solved, I'm having the same problems but only in overdrive and once the transmission is hot. Click to expand... He hasn't been on here in just over a year. Maybe someone else will chime in, or you could start a new thread.
LONGJP2 TJ Expert Lifetime Supporting Member Joined Aug 11, 2019 Messages 5,852 Location S. Illinois Aug 20, 2024 #22 madridalejandro said: Did you end up getting this solved, I'm having the same problems but only in overdrive and once the transmission is hot. Click to expand... Guess he didn't. He's back. https://wranglertjforum.com/threads/transmission-code-p1776.64778/
hear Can't type Lifetime Supporting Member Joined Oct 18, 2020 Messages 6,069 Location Prosper, TX Aug 21, 2024 #23 madridalejandro said: Did you end up getting this solved, I'm having the same problems but only in overdrive and once the transmission is hot. Click to expand... you should start a new thread with your specific details. This one is 2 years old and several of the people have long since taken their ball and gone home.
