I have a 2006 Unlimited with a automatic trans that has started to shift hard from 1st gear into 2nd. It happens when the jeep is typically cold and it only happens once. I checked the transmission fluid and it was very low at normal operating temps and didn't register on the dipstick. I slowly added trans fluid and kept checking to see the progress on the dipstick. I made sure it up to operating temp, put in neutral and repeatedly added about 8oz then checked to see where it was on the dipstick. I eventually got the fluid about 1/2 way between cold and hot marks on the dipstick by adding about 3/4 of the quart into the trans. Note, when hot, the fluid got to about 1/2 way between the cold and hot mark on the dip stick. Now that everything has been sitting for a few hours, the fluid level it at the hot mark. What am I missing and is this something to worry about.
