4WD Troubleshooting
The linkage is not so easy to work on due to it being up there behind the skid plate but let me be the first to warn you about removing the skid. Some unsuspecting new TJ owners have unbolted that skid without realizing that is is also the cross member that supports the transmission and transfer case, if you do that the transmission will drop and you can damage motor mounts, bend the exhaust and damage the radiator fan and shroud. To remove that skid you have to support the transmission, remove the transmission mount bolts then remove the six skid bolts.
You can still access the linkage with the skid in place but I wanted to let you know about it anyway in case you decide to remove it someday.
Reactions: JeepGirl1013
Thank you! I did actually know that 😂 why I know that and not what my linkage looks like, we’ll never know
I drew an arrow on Tonyarm's picture showing the 13mm adjusting bolt. With long arms (no pun intended Tony) and a 13mm box wrench you can reach in from both sides of the skid, hold the wrench on the bolt with one hand and turn it with the other (you won't really be able to see anything while both your arms are in there, just feel). I used a long 13mm ratcheting wrench. After I got mine all adjusted and lubed I thought I was good to go but on a trip in the mountains it gave out on me again and I had to crawl underneath. After that I ordered a cable kit.
Reactions: TonyArms
