- Joined
- Mar 20, 2016
- Messages
- 1
Hey guys thanks in advance.
i have a 98 that im installing a rough country 6" lift with adjustable control arms.
when i bought the jeep the axles were removed by previous owner and he lost all of the factory control arms.
Ive looked online and i find anywhere from 15" to 17" as a base starting point on lower arms and uppers get adjusted accordingly. i understand every build is different.
i was hoping someone on here has the same 6" RC lift with adjustable upper and lower control arms and could help me out with what your lower arm lengths are from center of bolts
this pic is with the axle extended almost all the way to the ground it was just a mock up to see how everything was fitting together
ive installed my rear axle and upper and lower arms using the spring correction plates and the lowers are at 17"s right now. that gives me just enough room for the rear track bar to clear the gas tank. but looking at the spring alignment it looks like the axle needs to be moved to the back more but if i do that the track bar will hit the gas tank.
if anyone has pics of theres installed that would help too.
