AC holding pressure but not vacuum?
vrtillman
Texas
Anyone know what's going on? I went to recharge my AC system after replacing some lines and doing my heater core. It will only pull about 14-16 inHg and loses vacuum in about 15 minutes after I turn the pump off and shut the valves. Consequently, when I fill the system with argon to pressure test (~50psi), no audible leaks anywhere, no soapy bubbles at connection points, and its still holding 50 psi after about 3 hours. I know it was originally leaking out of the high pressure Schrader valve which I already replaced once, so I ended up replacing the whole manifold/line. I don't want to recharge with refrigerant unless I can pull full vacuum (25-30 inHg) and hold it for at least an hour.
Sounds like you have a leak under vacuum. Did you replace seals, or did you reuse the old ones? I would recheck your connections.
You do need to be able to pull 30 inHG, but there is no need to have it hold for an hour. I run the leak test for 10 minutes and then recharge.
When my a/c failed, the guy pulled a vacuum on it, let it sit for 1/2 hour, and pronounced it good. Serviced it and gave back. A week later, when it quit cooling again, he pressure tested it and this time found a pinhole in the condenser. Replaced that, and it still cools, 3 years later.
Reactions: Blondie70
