My '02 had no AC the other day, and after jumping the low pressure switch I diagnosed low refrigerant as the culprit.
I ran a can of 134a with dye into the system, but couldn't find any obvious leaks under the UV light. There was nothing coming from any of the hoses or shrader valves, nothing at the condenser or the pump, and no water was coming out of the evap drain but I didn't see any dye around it either.
What's the next best move here? Was thinking I should vacuum it and see if it holds pressure, and if so then refill it? Let the AC run for a while longer (I gave it about 15-20 minutes) and then recheck?
Seems like the only other place to be leaking would be the evaporator which could be hard to diagnose. This is the first time it's lost refrigerant in the 25 years we've owned it, so I'm wondering if it's a super slow leak, and maybe a quick vacuum/recharge is all that's needed? Appreciate suggestions, I'm no AC expert!
