Advice - Build up to 33s
GeorgeB
Lifetime Supporting Member
Nazareth,PA
I started out with a completely stock 06 X with the 6 speed and plan to build out to 33s. Currently built up to 31s with OME 2.5" lift and t-case drop. Still.habe stock gears. Also have full set of Metalcloak double adjustable arms (front and rear; set to stock lengths).
In the essence of $$$$/wife that is not understanding to such things, I was thinking of a phase 2 with adding a DC driveshaft, SYE and adjustable rear track bar. Next summer plan to finish off the expensive part...regear, lockers, axles (likely sticking with the Dana 35), body lift etc.
Are there any red flags with this approach or should I pursue a different plan?
TIA
TIA
This should be in the TJ general section unless you are doing a build thread on your Jeep.
You'll get more answers there.
A lot of information in the resource area.
https://wranglertjforum.com/forums/tj-resources.121/
https://wranglertjforum.com/threads/a-beginners-guide-to-lifting-your-jeep-wrangler-tj.733/
https://wranglertjforum.com/threads/the-official-sye-slip-yoke-eliminator-thread.100/
