Hello everybody,
I've been visiting the forum for years and have learned so much through this amazing site, and I finally am coming to you guys about an issue I've been having for years now. While I want to provide as much information as possible, I will keep it as brief as possible. I hope you guys like mysteries because this one is a doozy.
*2005 Jeep Wrangler LJ 4.0 6-spd manual 155k miles
Over the last 3 years, it's slowly gotten worse, and a massive amount of time, effort, and money later, the problem is still unsolved.
Some background: First time I remember having a weird misfire was a couple years ago after flooring it on the road and accidently hitting the limiter a couple times, noticed it at idle when I got back home, and it went away. Then, over the months and years, almost every time I got on it hard, it would have a weird rough idle/slight miss at idle. Sometimes it would get especially bad, and the miss would continue through the RPM range, but if I'm easy on it and drive it nice, it almost would always go away. Now more recently (Last year or so) It's gotten worse to the point that if I sit and idle for a while (Drivethru) The roughness gets worse and worse until it throws P0301 and P0300 codes (Cyl 1 misfire and random multiple misfires), and the CEL will often flash. It often has a richness smell to the exhaust. But what's happened in the last few weeks has almost pushed me over the edge. It's been hard starting (4x the average time on the starter before it fires up) and it's started bucking slightly at low RPM cruising leaving the neighborhood, and hesitates slightly sometimes giving it a tap of the gas in neutral.
I've been chasing this issue and here's everything related to it that I have replaced:
-Spark plugs (At least 6 times, multiple different brands, was running NGK ZFR5Ns and recently swapped them out with Champions, but nonetheless, the condition doesn't get worse or better on plugs so I've ruled that out)
-OEM coil rail replaced with Crown coil rail when my OEM one failed, however it didn't fix the issue. Currently running a K Suspension Viper Coil Mod* thinking it was still coil related with no change (Great product, makes messing with anything ignition-wise much easier)
-Cats replaced with flowmaster (Pre-covid when they were $250 for a set, now they're over $1,000) with 2.5in exhaust all the way back.
-OEM Injectors replaced with 12-port injectors, made condition slightly worse and threw rich codes, replaced with remanned 4-hole injectors and rich codes stopped. Underlying issue remained the same throughout.
-OEM OPDA somehow came (slightly) loose on a drive once in 2020, creating a minor oil leak and threw the OPDA codes with limp mode, shop tightened it back up when taken for diag (Likely unrelated, but wanted to include it). Last year I replaced the OEM OPDA with a Crown unit and crown cam sensor under suspicion of it being a worn cam/OPDA* (No monkey noises). This actually seemed to have solved the issue for a bit, I remember it driving great for a week or so before slowly coming back.
-Cam sensor replaced with a NAPA one a couple weeks ago on suspicion of it being the crown one, no change to issue. $50 wasted.
Now here's the kicker:
This is almost exclusively an idle issue, after throwing some new plugs and the cam sensor in it (Which was a hail Mary that fixed nothing) I drove it from NY to FL with no issues aside from hard starts and rough idles. It's still reliable as hell, and it hasn't blown up on me (yet). Once she's off idle, she's absolutely fine. I got 17.5mpg (That .5 really matters to me!) all the way down sitting at 2800rpm going 75mph without a single hiccup. No knocks, ticks, weird noises when cold, warm etc. Once it's driving it's fine, just low rpm stuff. So I think that rules out stuff like fuel pump, lifters, or anything else that would be associated with high RPM power loss.
This leads me to believe it's 1 of 2 things.
1: Cam related: Worn lobes from the OPDA oiling issues or something. I actually spent $700 on cam parts to do the swap, I had it all on the floor in my garage, with the Jeep sitting ready to go under the knife, but I couldn't bring myself to do it. At the time I 95% believed it was the cam, however that 5% kept me from pulling the trigger, I returned everything.
2. Wiring: Engine wiring that has gotten cooked and fragile over the years, while I see some crumbling plastic covers on the wiring, I see no signs of wear or unusual damage to the harness anywhere, especially the main harness behind the firewall. This is what I truly think it is. But would a wiring issue go away with high RPM?
What do you guys think? This has driven me absolutely nuts and as I inch closer to an LS swap I just wanted to see what you guys think, or if anyone's had this absolutely unusual nightmare of an issue on their OPDA equipped 4.0. Also take a look at the spark plugs* after I pulled them, notice plugs 1 and 6 have slightly more carbon buildup than the rest? But if it was the wiring for cyl 1&6 which share the same wire, wouldn't I have a cyl 6 misfire as much as cyl 1? I think it's possibly wiring nonetheless. Apologies for the long post, I'm just stumped. If you guys want I can add more pics of engine bay, video of it hard starting and idling if you want.
*Attached are some pictures: 1: My Jeep after she made it to Florida 2: The K Suspension Coil Mod for those who aren't familiar. 3&4: Best pics of cam and OPDA wear I have. 5: My latest spark plugs pulled (cyl 1 is on the right, cyl 6 is on the left) (I know there's only 5, one of the middle ones is missing but it's identical to the others)
