It’s an off-season projectWhat it could be...
Maybe I could have worded it better . The gap I’m talking about is not from installing an AntiRock but from removing the factory sway bar and it’s plastic cover .OK. I guess I would not call that a gap that is left when you install the antirock but at least I know what we are talking about.
The primary value is that the larger winch deck turns the bumper into a very large gusset that adds a considerable amount of strength to the frame.I like the way the Savvy fills the gap where the factory sway bar was located . The TJ I bought has a cheap bumper that leaves a big gap there . I also like how the Savvy allows you to move the winch back a couple of inches on the bumper if the factory sway bar has been removed
Do you feel there’s a benefit to having your modified aftermarket steel bumper compared to the aluminum Savvy ?What it could be...
Mine was a bit less expensive and welding stuff to it is easier. But it weighs 2-3x as much as Savvy and it took an entire weekend to remake. I copied everything I could, but I still think Savvy is the better bumper.Do you feel there’s a benefit to having your modified aftermarket steel bumper compared to the aluminum Savvy ?
For anyone buying, just be sure to get the hardcore upgrade. At least if you wheel moderately hard.Mine was a bit less expensive and welding stuff to it is easier. But it weighs 2-3x as much as Savvy and it took an entire weekend to remake. I copied everything I could, but I still think Savvy is the better bumper.
However, it doesn't look near as bad if you clean it up and throw some paint on the frame.
That’s a big improvement compared to mineThis may tell the story better on the warn. It has a lip at the back that covers the factory sway bar, so at least in the middle it doesn't really leave a gap. The savvy seems to cover at bit better right on top of the frame. The warn only uses the front sway bracket bolt hole.
Maybe the front gap balances out the back crack?![]()
View attachment 282766View attachment 282765
Here you go: https://absolute-wits-end.com/air-coupler-bracket-guarded-kit/Do you have link to the bracket that is shown for air. Like that much better than going through grill
