I'd like to install the Currie flat tow brackets, but I also have a Swayloc sitting in the box ready to install at some point. Does anyone know off hand if there will be a clearance issue with the bolt and nut from the Currie bracket that goes through the front crossmember and the outer torsion tube on the SwayLoc? I've seen it done before with the Antirock, but I can't seem to find any SwayLoc examples. Thanks.
